14" Vertical Metal-Cutting Band Saw
South Bend’s 14" vertical metalcutting band saw features variable speed blade control ranging from 82 to 384 ft. per min.
South Bend’s 14" vertical metalcutting band saw features variable speed blade control ranging from 82 to 384 ft. per min. The band saw includes an on-board cutting, welding, annealing and grinding station for band saw blades. The band saw is suited for making internal contour cuts. For increased accuracy, a built-in chip blower keeps the cutting line-of-sight cleared.
Other features include NSK bearings, Allen Bradley controls and heavy-duty castings and components. Two models are available: The SB1012 model features a 1-hp, 110V/220-V, 1-phase, 60-Hz motor, and the SB1013 model features a 1-hp, 220-V, 3-phase, 60-Hz motor.
