3D Viewer Enables NC Data Sharing
Spring Technologies’ NCSIMUL Player 9 enables sharing of simulated 3D machining jobs.
Spring Technologies’ NCSIMUL Player 9 enables sharing of simulated 3D machining jobs. Users can analyze, manipulate and display NC programs and machining simulations in real time, block by block or as an end result through the 3D viewer. The program features new and updated functions, including simulation review, 3D functional dimensioning, a measurement tool, an integrated screen capture tool, and a display that enables realistic renderings and interaction with the 3D geometry.
The viewing technology is backward- and bidirectional-compatible between 32- and 64-bit operating systems. Additionally, the viewer can display the contents of a machining job generated by NCSIMUL Machine down to version 8.9.4. A touch interface enables 3D manipulation and quick access to functions, while a “tile” application in the Windows 8 Pro environment provides direct access to 3D movies. Additionally, the program can be integrated with other NCSIMUL products, and 3D machining movies can be incorporated into production documentation via NCdoc or NCSIMUL Publisher, or as an attachment to the NC program via NCSimul DNC.
The program uses the np3 format, said to enhance collaboration around NC data. According to the company, the simulation data is accessible to all other manufacturing processes, and can be incorporated into technical documentation, instruction sheets, project reviews and more. The ability to reuse NC information enables the sharing of data across programmers, operators, and workshop and project managers.
When to Use Custom Macros With a CAM System
Custom macros can offer benefits even when using a CAM system to prepare programs – but must be implemented with the right considerations.
Large-Format Machining With Small Cutting Tools and Dynamic Motion
Napoleon Machine, a defense contractor that provides parts for the M1 Abrams tank, recently took advantage of a CAM feature that allowed the company to streamline its cutting strategies and program offline. Here’s how the shop cut cycle times nearly in half with its large-format five-axis machining operations.
Finally, A Comprehensive Software Solution Designed for Small Job Shops
