The Tsugami B0 385 38-mm, five-axis, Swiss-type turning center has an integral double spindle and capacity to hold 20-mm-diameter turning tools. A 15-hp main spindle with maximum turning speed of 6,000 rpm readily handles challenging materials while holding tight tolerances, the company says. The turning center provides simultaneous operation of the main and subspindle and features a modular tool zone that permits quick and easy change-overs. Also available is the Tsugami S207 20-mm, Swiss-type turning center with continuous B-axis movement.
