This sample study part was cut from aluminum on a wire EDM. An identical sample study part was cut on an AWJ machine. The part would fit in a rectangle the size of a standard playing card.
The Mitsubishi FA10S wire EDM, which was used in the test cut, is representative of current wire EDM technology.
The Suprema waterjet machine has four-axis capability that allows the waterjet stream to be tilted for cutting complex contours. Tilting capability is also used to counteract the slight tapering effect produced by the natural shape of the waterjet stream.
Wire EDM and abrasive waterjet (AWJ) are increasingly seen as highly
complementary processes. The combination takes advantage of the speed
of AWJ and the high accuracy of wire EDM. AWJ is used for rough cutting
and wire EDM is used for finish cutting to tight tolerances and very
fine surface finishes. The result can be a significant reduction in
overall production time.
One of the most promising
applications for this combination is cutting aluminum because the
advantage of roughing with AWJ and skim cutting with wire EDM are
particularly strong for this material. Complex, close-tolerance
aluminum components are proliferating in many key industries such as
electronics, aerospace and defense. OEMs are looking for shops that can
make these parts quickly and economically, and production strategies
that use wire EDM and AWJ to reduce the number of process steps and to
streamline individual steps are bound to be winners. Advances in the
latest generation of waterjet equipment further enhance this effect.
To get a glimpse of how the combo of wire EDM and AWJ can improve
productively with wire EDM, we asked MC Machinery Systems Inc. (Wood
Dale, Illinois) to examine and discuss a sample study part, shown
above. MC Machinery Systems is the North American source for wire and
ram EDM technologies from Mitsubishi EDM and the line of AWJ machines
branded as Waterjet Powered by Mitsubishi Electric. The same part was
produced entirely on a wire EDM and then again on an AWJ machine. The
table on the next page compares the two processes and summarizes the
results.
The sample part is half-inch thick 6061 aluminum.
The part’s outside dimensions measure 2.5 by 3.0 inches. The inside
shape is a scaled-down version of the outside contour with 0.020-inch
inside radii. The outside radii are sharp.
The EDM test
cut was performed on a Mitsubishi FA10S using 0.010 brass wire. The
machine’s travels are 10 by 14 by 8.6 inches. To replicate results that
the typical user could expect in the field under normal operating
conditions, machining parameters were derived from the set of standard
technology settings resident in the control software. The achievable
surface finish is 50 microinch Ra in aluminum with four skim cuts. Two
start holes were needed, one for the inside and one for the outside
shapes. A similar test was performed in steel, achieving 10 microinch
Ra with the appropriate technology.
The AWJ test cut was
performed on a Suprema 1200 Waterjet Powered by Mitsubishi Electric.
The machine travels are 48 by 48 inches with 6-inch cutting height in
Z. This model is equipped with a 60-hp waterjet pump designed to create
as much as 60,000 psi of cutting pressure. The Suprema also has a
standard feature called Intelligent Tapering Control (ITC) that allows
faster cutting while maintaining side wall straightness. Similar to the
wire EDM test cut, this test cut used machining parameters that would
be applied in a typical user application.
At first
glance, it might seem that the speed of the AWJ for roughing in this
case is the whole story. However, according to Steve Szczesniak,
national waterjet product manager for MC Machinery Systems, there is
more to it than that. For one thing, he says, AWJ has benefits that may
help shops overcome reluctance to wirecut aluminum. For another, not
all rough cuts with AWJ are the same. Users can select the parameters
that help them optimize the results in conjunction with wire EDM skim
cuts.
Wire EDM And AWJ Test Cuts
Material: ½-inch thick aluminum. Total length of cut is about 16 inches. |
EDM Cut Information
| Cut Time | Surface Finish |
| Rough Cut | 24.24 minutes | 190 µ inch Ra |
| Skim 1 | 25.4 minutes | 90 µ inch Ra |
| Skim 2 | 24.24 minutes | 82 µ inch Ra |
| Skim 3 | 26.22 minutes | 58 µ inch Ra |
| Skim 4 | 28.57 minutes | 50 µ inch Ra |
| Total Cut Time | 2 hours 8 minutes | |
| Abrasive Waterjet Cut Information | Cut Time | Surface Finish |
| 60,000 psi with 120-mesh abrasive | 6.4 minutes | 85 µ inch Ra |
| The results of the test cuts show a significant reduction in rough cutting time with AWJ. In this case, a 73-percent time savings was achieved with AWJ, not counting time saved because no start holes were needed. |
The Trouble With Aluminum
Because
cutting aluminum with wire EDM has some undesirable drawbacks, some
shops try to avoid the process, especially if they also wirecut steel
or graphite. One problem with wirecutting aluminum is the large volume
of debris particles created during the process. It can quickly clog an
EDM filtration system.
These
particles are an unavoidable by-product of EDM, which is a thermal
process. In a sequence that occurs thousands of times a second, EDM
uses the extremely high temperature created by the flow of electrical
current in each “spark” to form a microscopic bubble of vaporized
material just below the workpiece surface. When this bubble expands and
bursts, it expels molten bits of the parent workpiece material into the
dielectric fluid, where they solidify. The particles created by
wirecutting aluminum are very small and very hard. They shorten the
life of certain types of filter media and cause the filter cartridges
to be changed more often. Disposal of filters containing these
particles is costly, and they are not easily recycled. In addition, if
these particles remain in the wire EDM dielectric system, they can
interfere with the wire cutting of other materials or contaminate the
workpiece surfaces.
Because rough cutting a part from a
solid blank with EDM removes considerably more material than subsequent
skim cuts, finding an alternative process for this step is very
attractive. Laser cutting is a possibility, but cutting aluminum in
thicknesses greater than ½ inch is difficult. Laser cutting also
creates a heat-affected zone that is not easily removed with skim
cutting on a wire EDM unit.
Why Rough Cut With AWJ?
AWJ does
not face these difficulties. AWJ uses a high-pressure stream of water
containing an abrasive grit (usually pulverized garnet) that
aggressively wears away the workpiece material as it blasts across the
surface. AWJ does not heat or distort the material it is cutting.
Chunks of material cut away by AWJ are perfectly suitable to be used
for other jobs. Also, AWJ does not need a start hole—it can create its
own by piercing the material directly.
However,
cutting with a high-pressure steam of water differs in several critical
ways from cutting with an energized wire as EDM does. The cutting
action of AWJ changes with distance from the nozzle, whereas the
cutting action of the wire is virtually the same throughout the full
length of its engagement (assuming that flushing conditions are
uniform.) With AWJ, the stream begins to lose pressure and spread out
as it leaves the orifice. It also deflects away from the direction of
travel as a function of axis travel speed. All of these factors degrade
the accuracy and surface finish, and the effects are more noticeable
depending on the height of the cut.
Overcoming “Jet Lag”
Recent
developments in waterjet technology are able to provide considerable
compensation for these natural tendencies in the cutting action of AWJ.
For example, the intelligent tapering control system on the Suprema
model used in the test cut tilts the high-pressure waterjet as much ±6
degrees to correct for the spread of the stream. This system hinges on
the machine’s four-axis configuration. According to Mr. Szczesniak,
this feature allows faster cutting speeds in a contour and is the key
to moving directly to skimcutting.
The
company’s five-axis Evolution 3D System includes a further refinement
that enhances AWJ results. This system uses a self-positioning device
that references a rotation point on the surface of the workpiece near
the cutting nozzle, thereby maintaining a constant distance between the
surface and the nozzle when following 3D geometry.
These
developments help AWJ create a smoother, straighter and more consistent
surface that may require fewer skim cuts to achieve the desired
accuracy and surface finish.
Additional Cutting Tips
Mr. Szczesniak has the following recommendations for maximizing the
value of rough cutting with AWJ as a prelude to wire EDM:
- Use
the correct nozzle and orifice for the geometry detail required. This
will allow you to rough out as much detail as possible during the
waterjet cutting process and avoid re-roughing on the EDM. The smaller
the orifice size, the smaller the attainable radius. However, cutting
speeds have to be decreased accordingly.
- Wall
straightness affects the number of skimcuts needed on the wire EDM.
Taper control is necessary to cut parts as straight as possible on a
waterjet. It also minimizes total cut time.
- The
finer the abrasive used in AWJ, the finer the finish achievable with
the process. However, finer abrasives cut less aggressively and
increase cutting time proportionately. In most cases, the best strategy
is to use the finest abrasive on the waterjet and the least number of
skimcuts on the EDM.
