Abrasive Products for Metal Finishing
Brush Research Manufacturing will display its Flex-Hone tools for finishing and deburring virtually any type or size of cylinder.
New Product From: 8/19/2013 Modern Machine Shop
Brush Research Manufacturing will display its Flex-Hone tools for finishing and deburring virtually any type or size of cylinder. The self-centering tools conform to the bore surface and feature round, abrasive globules mounted to the end of flexible nylon filaments. They are said to provide a consistent, even surface finish. Nine different abrasive types and 11 grit selections are available.
The company will also showcase its Nampower abrasive disc brushes, available in dot and turbine style for light and heavy deburring, and its miniature abrasive nylon brushes for removing burrs and producing an edge radius on small-diameter holes.
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Drilling, routing, milling, reaming.
AMAMCO Tool engineers custom tooling for your most critical applications.
  • Techspex
