Abrasive Removal System
The Barton Abrasive Removal Tool (BART) is a portable system designed to remove abrasive.
New Product From: 7/1/2010 Modern Machine Shop
The Barton Abrasive Removal Tool (BART) is a portable system designed to remove abrasive. Powered by a common pressure washer, garnet removal rates range to more than 2,000 lbs. per hr. The system’s stainless steel wand is designed to fit between table slats and can be operated while the waterjet is running. According to the company, the system is easy to operate and can be used on multiple machines.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Barton International
MMS Zones
Zones
