Free Webinar: Accuracy from the Very First Part
A free webinar brought to you by Heidenhain will explain how direct position measurement feedback systems can eliminate positioning errors due to thermal fluctuations.
Thermal effects generated by internal heat sources or environmental changes limit a machine tool’s repeatability and, as a consequence, the accuracy of the parts being produced. Over a typical production run during batch production, deviations between parts can manifest creating unacceptable parts. A free webinar brought to you by Heidenhain will explain how proper implementation of direct position measurement feedback systems, on linear and angular axes, most thermal errors in the position loop can be eliminated.
More specifically, the webinar with question and answer session will address heat sources in machine tools, position measurement’s influence on accuracy and reduction of kinematic errors with closed-loop technology.
This hour-long webinar will be held at 2:00 EDT on Wednesday, March 21. Click here to register.
