Let's go ahead and start the demonstration. We will start it with
production machining. We are going to look at basic 3-axis milling,
maybe of a billet or of a casting. We will look at 2-axis turning. As
you examine a CAM system, some of the technologies to look for include
a really low-level of tool control. You need to be able to put the tool
right where you want it, at just the right speed. You need to have that
sort of APT-level control but have it in an automated CAM system. You
need high-speed milling functions. A lot of technology goes into that,
as it is not just cranking up the speed. We have to slow down at
corners and always round off the corners, functions such as that, so
look for that in a system. We want to be able to rough the part out
with extremely complex re-roughing - put the tool only where the
previous tool left material, don't waste time machining air. Maybe we
need multiple levels of re-roughing. And finally, we have to have
simulation. We want to know for certain that the toolpath is exactly
how we want it before we ever go out to the shop floor.
So,
here is the model that we will be working with today, a new design for
a skid-steer loader. One of the important things for your CAM system
should be the capability to take the entire model from the customer,
not just single piece part files. In this case I am going to start with
a top-level assembly and drill down in to the bill of materials, and
here is our cooling system, a new design with dual pathways for
airflow. One of the key pieces of this design is this blue fan blade in
the middle, so let's open that model up and examine it. This is the
piece we need to work with today. Maybe we need to cut this out of a
billet of aluminum to make a prototype for example.
This is
the model I want to work with, so again, I don't want to any sort of
translation. I want to simply put it inside of a manufacturing
assembly, using the same system. In this case I have the design model
inside of a workpiece, in this case the billet. I should be able to
model any kind of fixtures, any kind of custom holding devices. I start
out by defining my machine, and again since I am in one system, I can
choose from a mill, a lathe, a mill/turn, or wire EDM, and it can be a
3, 4, or 5-axis mill. I define my starting location, I define my tools,
and I am ready to start cutting.
Let's start with just a
roughing operation. I just take this tool, a 1 inch flat end mill, and
rough out everything that is not part. I have different options I can
choose, whether I want to have a spiral motion or maybe lace back and
forth or maybe a constant tool load, any number of options. I should be
able to simulate that toolpath, speed it up or slow it down or run it
block-by-block. I can zoom in on any given area and put the tool just
where I need to see it, to insure it is doing what I want.
You
can see here that I have started with conventional machining, turning
90 degrees or as needed for corners, but maybe I want to do this as
high-speed milling. I should be able to take that operation and say for
example every cut has a smooth radius, no hard corners, no hard stops.
I might make it a constant radius, or change it based on the angle. I
might put in a slowdown function, and as it approaches a corner, have
it add additional feedrates. Maybe I will drop it down to 50% and have
it increment the change over a couple of steps. I should be able to
define all of that, so that I can achieve a good, smooth ramp down and
ramp up. Maybe for plunging, I don't want to have any 90° plunges, so I
will put in a helical diameter and entry angle, so that every entry is
a constant, smooth entry.
So now I have that same roughing
motion, but redefined for high-speed milling. Every corner is a nice
smooth radius move, and every corner has a feedrate ramp up and a ramp
down. I can have exactly the tool motion that I need to achieve very
high feedrates with very shallow depths of cuts, and that allows me to
do my job, to get this part finished quickly, get it off the machine
and out to the customer, and I get to make my softball game at 5:00.
Now
that I have my roughing pass set up the way I like it for high-speed
milling, I will change tools, to maybe a œ inch bull nose cutter, but
all I want to machine is whatever was left. I want the system to look
at that previous toolpath, based on stock allowance, tool size, and
part geometry. In this case, that means I just need to walk around the
part, profiling the outside walls of the blades, machining all the way
down but only machining the material that was left during the previous
cut. I don't want any air machining or other extraneous motions. Once I
have that, I will move in to a finish or semi-finish cut. Let's take a
ball end mill and finish out the valleys between the blades. It is made
up of several surface patches, but I will treat them as one area, and
define the flow as following the outside contours. Not only will that
give me a smooth polished surface, it will be exactly the type of
surface finish that the aerodynamics guys would prefer. I will choose
my ball end mill, set a step over or, in a case like this, maybe give
the system a scallop height and set that surface finish, letting the
system determine an appropriate step over.
You have seen me
playing the toolpath inside of the CAM system. Simulation is really
key, and at any time I should be able to take, for example, let's take
the first roughing pass, and show it as a solid. I can show the
material being cut away, show the scallops and stair steps, all the
material being removed, and of course at all times watching for any
gouges, especially if I go in and enter some manual moves. I might run
just that one sequence, or I might run everything. I might want to set
up multiple windows, maybe an isometric view here on the left, but on
the top let's do a top view, and over on the bottom let's do a side
view. Now I can watch the simulation from all sides. Let's do the
roughing, let's do the reroughing, and visually I can see what the
operation is doing but also have the system watching for gouges and
fixture collisions, things I would really like to know about before I
ever go out to the floor. You can see the system changes colors as I
change tools, so in this case I have changed to my bull nosed cutter
for the rerough, maybe come in with a second rerough, in this case a 1°
taper tool since these blades have a taper to them. This will give me a
smooth profile finish, again only machining where material was left
from the previous cuts.
Once I have that I will take the ball
end mill and clean out those valleys. Anything I do once, something
like this on the valleys, I can subroutine around so that I don't have
to program each valley individually. If my machine controller can
handle subroutines, I will output the code as needed, and if not, I
will have the system simply output the code in full, as I still only
need to program an area once.
So that is looking pretty good,
I'm feeling pretty confident about my program. Now I mentioned earlier
that we also need really low level tool control. These have been fairly
high-level, such as rough out everything that is not part. Maybe I just
want to take that ball end mill and walk it down the tops of these
blades as a finish cut. I should be able to simply pick an edge, maybe
a sketched toolpath or maybe a drive curve, maybe just a wireframe
model, and just follow the tool along that edge. A really low level
tool control, maybe just a handful of GOTO's, whatever it takes. In
this case, let's drive down that edge. I will want to control things
like entry and exit, moving in a specific manner. I don't want to
plunge down to the start of the edge, so let's add a radial lead-in,
maybe a œ inch radius lead in and ramp in to the model. I'll do the
same thing for the exit, maybe a delta move or a helical exit, any sort
of low level command, even a CL command like an OPSTOP at the end of
the motion. That's the kind of control I will have to have to machine
truly complex parts like this.
So that looks good, I have my
smooth entry and exit, I have the motion I need, so let's close that.
Now, what always happens? This part is ready to go to the shop floor,
and what phone call do you always get? Well, this is when the customer
calls and says, "That 9 bladed model, no, we meant to say 6 blades." It
is very easy on their side, with a good CAD system, to change it from 9
blades to 6, but you have already programmed this model. This is where
it really pays to have a powerful CAD/CAM system that can go all the
way from art to part. Here is the design model, let's change it to only
have 6 blades. It might be a big, drastic change like this that you
need to accommodate, or it might be a tiny change. Maybe they go to the
root of this blade and change the radius from 3.100 to 3.150, something
you can hardly even see as you look at the model, but exactly the sort
of change that can scrap a part and send the Material Review Board in
to action.
What you want is to be able to simply bring that
changed model in to your manufacturing assembly, and it knows that it
is a 6 bladed design, and it knows that the root of the blade has moved
by .050. You tell it to recalculate the toolpaths, redoing the
roughing, the reroughing, all of the toolpaths, and just let the system
do all of the calculations. I still make the decisions like this is an
appropriate tool, maybe choose a larger or smaller tool, but that is
where I put in my expertise. I let the system do the grunt work to say
this part is changed.
Before we are done here, let's cover
one other area of production machining, namely turning. Back at our
cooling assembly, I have this shaft that I need to turn. As before, I
don't want to go to a different system to cut this out or waste machine
time with on-machine programming. Here I have my part, with no
translation, and I set it in a fixture like a chuck that can be as
simple or as complex as I like. I will put it inside of a workpiece and
then put some toolpaths to it. Just as in milling, simulation is key as
I need to be able to speed it up, slow it down, maybe rotate it around
and put it in the ZX plane, maybe even have multiple views. I need to
be able to see that my roughing is good, my grooving is good, my cutoff
tool works, with the same needs in the solid display. Simulation is
key, and low level tool control is key, just as it is in the milling
world.
That's what you want out of your manufacturing system.
You want it to be comprehensive to cover all of your manufacturing
needs. You want it to be accurate, you want that simulation to tell you
for certain that this toolpath will cut a good part, because that is
what production machining is all about.
