Air-Actuated Collet Chuck
Northfield Precision’s 5C collet chuck is interchangeable with its 4" chucks.
Northfield Precision’s 5C collet chuck is interchangeable with its 4" chucks. The air-actuated chuck uses standard air-feed tubes (wet or dry), and the same bolt pattern as the 4" models. It can run at speeds faster than 8,000 rpm. All components are hardened and ground to 58/3 R.C., and all diameters are ground within 1/10,000 TIR. The chuck uses standard 5C collets.
The company’s air chucks are suited for virtually any lathe, boring machine, grinder or VMC. Models include through-hole, high speed and quick-change. The chuck is available in SAE or metric sizes ranging from 3" to 18" (76 to 457 mm). Accuracies range from 0.001" to 0.00001" (0.254 m).
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
