Air Chuck with Top Tooling Improves Machine Efficiency
Northfield Precision Instrument offers the model 450 custom-designed air chucks to improve machine efficiency.
The company offers air chucks for lathes, boring machines, grinders and VMCs. Models include through-hole, high-speed and quick-change. Chucks are available in SAE or metric, in sizes ranging from 3" to 18" (76 to 457 mm). Accuracy ranges from 0.001" to 0.00001" (0.254 m).
Machining Vektek Hydraulic Swing Clamp Bodies Using Royal Products Collet Fixtures
A study in repeatable and flexible workholding by one OEM for another.
Simple Workholding for Robotic Automation
