Air Chucks Designed for Pipe Applications
Samchully Workholding will display its new PAC series of extended-stroke Mega Bore air chucks designed for the pipe and tubular market.
Samchully Workholding will display its new PAC series of extended-stroke Mega Bore air chucks designed for the pipe and tubular market. The chuck offers a full 1" of stroke per jaw for gripping around upsets and flanges. Eight chuck sizes are available with bores ranging from 5.51" to 22.04". The company will also display a range of rotary tables, power vises and steady rests.
When To Use A Collet Chuck
