Figure 1. The insert on the right with eccentric relief has a well-supported cutting edge. This profile lowers the cutting force and reduces the chance of insert edge chipping.
The solid end mill is a machine shop staple. Its positive cutting edge removes metal by slicing through the material, rather than by scraping. This reduces cutting forces, power required to make the cut and the possibility of inducing vibrations. These reasons are why solid end mills remain popular for low-horsepower machine tools with limited structural mass to dampen vibrations.
Solid end mills do require periodic regrinding, and there is a limit to how many times this can be done to a tool. As an alternative, manufacturers have designed indexable insert end mills with positive radial and axial rake angles to emulate the solid end mill's cutting action, while allowing insert indexing and changeout. Until recently, though, a key feature of the solid end mill—eccentric relief, or "margin"—has not been replicated in an indexable insert cutter.
Big Daishowa Seiki has developed what is says is the first indexable insert end mill to combine positive/positive rake angles with eccentric relief, a la the solid end mill. We had the opportunity to preview the company's Fullcut end mill while visiting its manufacturing facilities and technical center located on Awaji Island, just off the coast of Osaka, Japan. Now available in the United States from Big Kaiser, Big Daishowa's partner located in Elk Grove Village, Illinois, this end mill design combines smooth, low-force cutting with insert changeability, while eliminating regrinding.
Eccentric relief is the positively arched (convex) area behind the cutting edge, as shown on the right-hand image in Figure 1. The profile brings the insert's sharp cutting edge nearly even with the body diameter to provide greater edge support. Unlike a concave, negative profile with a high clearance angle that tends to cantilever the insert from the body, eccentric relief more effectively directs the forces from the cutting edge into the tool's body. This geometry is less likely to cause insert chipping, which is prone to occur at the start of a cut (when cutting forces are highest) or during interrupted cuts.
Lower cutting forces can permit higher speeds and feeds, without increasing the risk of chipping. The Fullcut's insert geometry allows for shoulder, slotting and facing operations, but it can't be used for Z-axis feeding operations, such as plunge cutting or boring.
The end mills range in diameter from 0.5 inch to 2.0 inch, with inserts tailored to each diameter to maintain proper geometry. Each insert can be indexed once. The end mills are available in straight shank and integral body designs (V-taper, HSK and Capto) for high rigidity.
Keys To Quality
Big Daishowa Seiki believes that shops aspiring to highest quality machining must have the highest quality machine, cutting tool and toolholder. The importance the company places on quality was evident while touring its large technical center/showroom and three manufacturing plants located on Japan's Awaji Island. The manufacturing facilities are prime examples of how cleanliness, automation and advanced processes such as hard milling ensure repeatability, accuracy and quality.
Attention to machining detail was also apparent. For example, when grinding the taper of toolholders that use retention knobs, the knob is installed and then preloaded during the grinding operation. This simulates the load the toolholder would experience if it were installed in a spindle in order to compensate for any distortion the retention knob might cause to the taper. Big Daishowa is also constantly looking to improve throughput, without compromising quality. To that end, the company is collaborating with Mori Seiki in the development of an ATC-equipped lathe for high-volume, unattended production. The impetus for this new machine was continuous 48-hour batch production of Big Daishowa toolholders.
The lathe is called the Duraturn, and it is being beta tested at the company's technology center. Essentially a turn/mill machine without milling capability, it has a B-axis head that can index to 0-, 45- and 90-degree positions, and an ATC that serves a 120-tool magazine. The large-capacity magazine allows the machine to be well stocked with multiple same-sized tools to accommodate many change-outs.
