Anca Upgrades FX5 Linear Grinding Spindle Power
Anca has upgraded its FX5 Linear’s grinding spindle from 9.5 kW to 12 kW, also offering a 19-kW upgrade. This power increase boosts productivity and flexibility.
Anca has upgraded its FX5 Linear two-wheel pack machine from a 9.5-kW grinding spindle to a spindle rated at 12 kW peak power, also offering a high-powered, 19-kW spindle option.
To keep cost per produced tool at a minimum, Anca says CNC tool grinders strive to achieve the shortest possible cycle times — and machine performance and grinding cycle time are linked to the power capabilities of the grinding spindle.
The company also says a commonly accepted industry practice to maximize removal rate is limiting the spindle load to between 30% and 40% for fluting operations. If the spindle load is likely to exceed 40%, tool manufacturers tend to allow for a second fluting pass, as this contributes to longer wheel life and lower wheel load.
The FX5’s 12 kW spindle can grind tools up to 10 mm in diameter in a single pass, but increasing the tool size to 12 mm requires a second grinding pass to keep the spindle load at 40%. The 19-kW spindle, however, grinds 12-mm tools at 40% — Anca’s tests showed the single-pass approach with this spindle saved one minute and four seconds compared to two passes at 12 kW.
Overall, Anca says the use of “One Pass Productivity” for tools with a 12-mm diameter translates into an increased output of 15.8%, producing 70 tools in an eight-hour shift compared to 60 tools with the new standard 12-kW spindle.
Anca acknowledges that complex cutting tools have further factors influencing grind cycles besides the tool geometry. These include the quality of the grinding wheel and an adequate supply of cooling liquid, the latter of which prevents thermal damage to the workpiece. As batch sizes increase, auto white-sticking also helps to achieve maximum output by frequently refreshing the wheel.
