ANCA's ToolRoom RN34 Software Eases Tool Balancing
ANCA’s ToolRoom RN34 supports ballnose cutting edges, which are suited for the aerospace, die/mold, general machining and power generation industries.
ANCA’s ToolRoom RN34, with support for complex endmill geometries, is designed to improve cutting tool manufacturers’ productivity in the aerospace, die/mold, general machining and power generation industries. The high complexity of endmills designed to minimize quality issues resulting from chatter influenced the development of Tool Balancing in ToolRoom RN34 release. According to the company, direct communication between design and simulation software packages has simplified and eased tool balancing.
While the ability to design and manufacture chatter-avoiding variable helix/lead and pitch pieces, as well as variable helix/lead pieces with angle changes along the flute, are long-standing software offerings, variable helix/pitch introduces uneven weight distribution throughout the tool and requires balancing at higher rpms.
To simplify creation of balanced tools, a graphical drag-and-drop designer cutting edge replaces the constant helix ballnose option. This new ballnose cutting edge, featuring optimized irregular helix curves, becomes available when switching from 2D projections of the cutting edge to 3D projections. These tools are recommended for die mold, power generation and aerospace applications.
Grinding a standard ballnose cutting tool with the correct chisel angle and relief, straightness and ball profile line form is difficult, but ToolRoom RN34 has simplified it by automating the entire process. The end-user only needs to choose the proper chisel style and new cycles will populate the grinding parameters automatically. This enables center cutting of ballnose tools and eliminates wear and tear of the tip section.
Other features within the latest version of ToolRoom RN34 include revamped ToolTypes. These include double-radius endmills, threadmills, lollipop cutters, countersink tools, pocket grinding applications, embedded grinding files, new grinding methods, chipbreaker operations, constant helix fir tree cutters, protection for grinding files, double margin drills, other enhancements in profile software and other ToolTypes.
10 Tips for Titanium
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
Best Practices: Machining Difficult Materials
