Kyocera MA90
App Connects Tool Presetter to Machine Control
Koma Precision’s Elbo Controlli tool presetter app is available through the Okuma App Store.
Koma Precision’s Elbo Controlli tool presetter app is available through the Okuma App Store. The app is designed to increase cutting accuracies and shop efficiency. It enables users to easily measure a tool’s radius and length and then directly send the offsets to the Okuma OSP-P control to update the local tool offset table. Physical measurements can be completed with the tool offset number and wear values. Once a valid measure is received from the presetter, the program will either allow data to be sent to the controller or will cancel the operation.
The app requires an Okuma machining center equipped with an OSP-P300 controller, an Elbo Controlli presetter such as the Sethy Six running software version 2.4 or above, and a valid network connection.
GWS Tool Group
Sumitomo
Iscar
Horn USA
Ingersoll Cutting Tools
SGS
Iscar
