Aqueous Cleaning System Designed for Turbine Blades
The BladeWash aqueous parts washer from MecWash Systems is designed for cleaning internal cooling channels in turbine blades, as well as other parts with internal bores and complex geometries.
The BladeWash aqueous parts washer from MecWash Systems is designed for cleaning internal cooling channels in turbine blades, as well as other parts with internal bores and complex geometries. According to the company, the system completely removes the casting media used in manufacturing so that the blades may be used in an engine assembly. Parts are held in a confined wash chamber, while the high-flow wash process flushes components with water at rates ranging from 256 to 475 gallons per min. (1,000 to 1,800 L/min.) depending on the component and fixturing.
Kyzen Solvents Provide Ease of Cleaning for Medical Parts
The Metalnox line of solvent products are designed to improve reliability and increase the ease of cleaning in vacuum and vapor degreasing processes.
Alliance Manufacturing's Cleaning Systems Use Safe Solvents
PMTS: The company’s vacuum degreasing machines use solvents to remove contaminants from manufactured parts without the use of water or scrubbing.
CTG's Parts Washing Machine Supports Lean Manufacturing
PMTS 2023: The Ransohoff LeanVeyor parts washing system reduces floor space requirements and provides optimized cleaning and drying performance.
