Moving to higher levels of machining technology, in the context of
this presentation, is 5-axis machining. Most of you are probably aware
of the advantages of 5-axis machining, but we’ll go over them quickly.
First,
you can begin reducing setups because you can reach up to five sides of
the part in a single setup. One can also reduce stack-up errors because
you’re reducing handling and operations. If you can minimize or
eliminate moving a part from one fixture to another, there are gains to
be made in accuracy.
Second, improved tool life comes with
the ability to use shorter, more rigid tools. This is true for a number
of applications though people often think of die/mold due to the
corners and cavities. Being able to angle the workpiece or spindle
allows you to shorten up the tool and also use more aggressive
feedrates if the tooling and material allow for it. This also allows
for higher rigidity and productivity, which reduces cycle times.
A
customer once stated his ability to simplify fixtures for low-volume
work: Being able to reach 5-sides can simplify your need for fixturing
to get to other sides of parts and reduce lead-times for your
consumers.
With 5-axis, you can also machine complex parts
from solid rather than cast for low-volume or prototype work. We see
this more and more—everything from aluminum to steel to iron castings,
even titanium—where a complex part can be produced straight from a
solid because of the investment required when manufacturing a cast
part. With full 5-axis capability, you can do some of that work much
more effectively.
We’re often told by customers who
acquire 5-axis capability that they are able to take on jobs that could
not have been considered previously. Continuous contour parts are now
an option, and on a 4-axis machine, you don’t have this option.
An
example of some of those applications is that these more traditional
5-axis works with complex shapes, like the hip joint you see here. This
is a mold with undercuts, which would be impossible without 5-axis
capability in this case. The bottom picture came from a solid block to
the contoured, complex shapes you see. And on the top is a blisk, with
a full 5-axis contoured part in titanium.
These parts are
3+2 parts. As we talk about 5-axis parts, we have to mention 2+3, or
3+2 machining, which uses the additional axis to position the part for
machining, but you’re not using the continuous contouring capability.
The 5-axis setup allows you to angle the part to machine complex parts
in fewer operations but without losing accuracy by having all 5 axes
move at the same time.
It also provides the benefit of
eliminating stack-up error from multiple setups. Using 5-axis can
improve your ability to machine parts more efficiently, as you can see.
