What you’re looking at here is our topic for today. We’re referring
to the 5-axis machining, which you can see in the sample aircraft
airframe part on the left, and on the right is an automated setup with
a pallet management system.
The idea is to put these two
production advantages together to give you a flexible, simple, highly
productive method of producing parts. In this particular case, we’re
talking about processing the parts across a 5-axis horizontal machining
center.
The advantage of horizontal machining centers is
that you have better chip management and coolant management system to
run longer hours, unattended, without having to intervene with cleaning
up the machine and things like that.
What we’re going to
illustrate here is setting up parts onto standardized sub-pallets
outside the cell. The advantage of this is that the machine and cell
can always be producing parts, never stopping, while new parts are
being set up.
We’re running nonstop by using a
pallet-magazine approach. We’re going to show you a video in a bit to
illustrate an automated 5-axis cell. The video will show a process of
accomplishing 5-axis machining in a way that’s simple and actually
being done in the real world. You can see how the customer is
benefiting and how they are running parts every day.
This
type of automation works for a lot of one or lots of thousands, which
is really the highlight of the flexibility of the system. Many people
are running smaller lots and higher mixes of parts, which demonstrates
how you can use this type of setup to run lots as they are needed.
What
we’re going to show in the video is a micro-MMC. It presents Makino
technologies, although I want you to look at it to see how a 5-axis
horizontal machining cell can be integrated with a robot-loading system
and palletizing system.
One interesting thing you’ll see
is that the robot utilizes a single, standard gripper. This is
important because using a standard gripper allows us to be much more
flexible. Parts are loaded on the sub-pallets, so there’s no reason to
use different grippers for different parts, since all parts can be put
on the same standard sub-pallet, adding to the simplicity of the
system.
This type of a system can be created as a more or
less stand-alone machine that’s highly automated, or it can be run as a
multi-machine, multi-pallet configuration where you would use a cell
controller. If it’s a stand-alone or single-machine operation, it can
all be controlled from the machine controller.
Externally
worksetting station is an important aspect of the setup. As you look at
the picture, you can see the curved surface, which is the worksetting
station. The machine can be running and producing parts at all times
while an operation is loading new parts or taking out finished parts.
Pallet
stockers you’ll see much better in the video, but there can be any
variety of configurations of this. The unique feature of this system is
that the pallet stockers are in more of a vertical orientation, taking
up very little space. So you have a highly automated, very productive
system that is taking up limited floor space.
I mentioned
horizontals are great for chip and coolant management, but they’re also
great for the pallet-stocker side of this system. This can help direct
coolant, simply using gravity, to manage coolant left on the part and
return that to the coolant sump, so you don’t waste a lot of coolant.
