The business issues here include cutting lead-times. In many cases,
we’ve seen people who automate a 5-axis system and cut their lead-times
in half. The ability to easily run low volumes is really a big part of
this.
You can significantly reduce WIP and finished goods
inventory, mostly because you can do the parts in fewer operations and
not have parts sit between operations.
Increased equipment
utilization has a huge impact on the manufacturing capacity of a single
machine. Minimizing direct and indirect labor is a concept typically
operated by a single person, which means you can increase output
without increasing labor.
You can eliminate setup simply
because the machine is always producing while you’re setting up, which
means the machine doesn’t wait on setup.
Flexibility: we
mentioned large and small lots. With the 5-axis capability, you’re
handling parts less often, leading to reduced stack-up errors, which
will also improve quality and part-to-part consistency.
With
that, I’d like to show this video. What you’re going to see is a
manufacturing process that includes an actual case study. This
particular company is a high-level job shop, meaning that they do a lot
of complex parts, which is one reason they went with the 5-axis setup.
So they had a need for automation to increase the spindle utilization.
The application is an aerospace-type part, an airframe. And you’ll see
the part as we run this video. Please sit back and enjoy this video.
