Makino has developed a new pallet system concept called the
work-holding pallet system. This system enables smart workpiece setups
suitable for multi-faced machining.
A horizontal machining center serves as the core machine. The first
machine pallet has a 4-axis specification. There is another 5-axis
specification created by adding a rotary table. This combined use of
two different tables achieves highly flexible operation.
One
of the strong parts of the horizontal machining center is that chips
naturally fall down below. The machine design is advantageous to an
unmanned operation, because it avoids the problem of chips getting
caught in the spindle taper.
Makino developed the
work-holding pallet system to facilitate efficient multi-faced machine
in one chucking operation on 5-axis horizontal machining centers.
Work-holding
pallets, 30 mm in thickness, are available in two sizes, 400 by 400 mm
and 400 by 500 mm. The pallet is provided with multiple holes for
attaching the workpiece or a jig plate. The underside of the pallet has
two pull-stud bolts for attaching the pallet to a rotary table or an
angle plate.
The workpiece is attached to the pallets by
bolts that are inserted through holes on the underside of the pallet.
The pull-stud bolts have a reference line that can be used for
positioning to achieve repeatability within plus or minus 2 microns.
With
a total clamping force of 30KN, the pallet is designed to withstand
even heavy-duty cutting operations. The pallet system minimizes the use
of clamping and vices, which avoids creating areas where interference
might occur, and enables multiple faces to be machined in one chucking
operation.
An air-vacuum circuit is available as an option
for holding a thin, plate-like workpiece using a vacuum chuck. We have
just seen the major features of the work-holding pallet system.
In
this first process, the workpiece is rough-machined using an angled
plate. Then, in the second process, the rotary table is used to execute
5-axis finishing machining. This combined use of two different tables
allows highly flexible operation.
Combining a robot with
the work-holding pallet system facilitates continuous, unmanned
operation. Because the robot’s hand can grasp the pallet, there is no
reason to have robot grips, which have to handle different part shapes.
One gripper alone can handle a large variety of workpieces.
The
work-holding pallet system successfully accommodates high-mix,
low-volume production, as well as production with varying levels of
volumes.
In tandem with a robot, it facilitates continuous unmanned operation at night and on weekends.
