Supertec Grinding Solutions
Automatic Side Grinder for Machining Carbide-Tipped Circular Saw Blades
Vollmer's FS 2A grinds the flanks of carbide-tipped circular saw blades with diameters ranging to 810 mm.
Vollmer's FS 2A grinds the flanks of carbide-tipped circular saw blades with diameters ranging to 810 mm. The hard-wearing machine complies with the demands of a modern side grinder, the company says.
The tooth flanks of the saw blades are machined on both sides at the same time by using two grinding wheels. Teeth are completely finish-ground in a single saw blade pass. The feed path can be adjusted using two dial gages.
Okamoto
Supertec PMGII Grinders
High Accuracy Linear Encoders
Okamoto
