Back-Facing Air Gun Cleans Debris from Internal Diameters
Exair's soft grip back blow safety air gun delivers a blast of air to blow debris and liquids from internal part features including pipe and hose interior diameters, channels, bores, holes and internal threads.
Exair's soft grip back blow safety air gun delivers a blast of air to blow debris and liquids from internal part features including pipe and hose interior diameters, channels, bores, holes and internal threads. The ergonomic design of the air gun keeps the operator's hand comfortable, so it can be used for hours without fatigue, according to the company.
An array of holes on the Model 1006SS back blow air nozzle provides a back-facing, 360-degree airflow to clear out coolant, chips and light oils from machining processes. This nozzle prevents chips from being blown further into a part, tube or pipe and eliminates the safety hazard of blowing debris out the far end of a pipe or tube. Air consumption is 22 scfm at 80 psig with a sound level of 80 dbA. The nozzle fits inside openings as small as 0.875" and is effective on diameters as large as 4". It is constructed of type 316 stainless steel for durability and corrosion resistance. The airflow that exits the nozzle cannot be blocked, which complies with OSHA standards. It is also CE-compliant.
Because airflow is directed back toward the operator, personal protective equipment is recommended. Chip shields to protect the operator from the exiting debris are available. Extension pipes from 12" to 72" provide reach for longer tube and pipe clean out.
168 Manufacturing's Coolant System Automates Delivery
PMTS 2023: FullShop systems monitor and replenish all CNC machine sumps with optimized top-off ratios before the coolant runs low.
Unist's Electronic Control Regulates Lubricant Delivery
Unist’s Pulse R electronic control ties into the system control solenoid valve and takes the place of a pneumatic pulse generator timer or logic block.
