Ballnose End Mills for Milling, Mold Applications
Data Flute will display its Die Mold series of solid carbide ballnose end mills for hard milling and mold applications.
Data Flute will display its Die Mold series of solid carbide ballnose end mills for hard milling and mold applications. The material and application-specific tools enable machinists to use the most productive high speed machining techniques to achieve superior finish, requiring little or no handwork, according to the company.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
