Band Saw Performs Quick Cuts on Stable Platform
Sawblade.com now offers the Trajan 20 heavy-duty band saw for efficient metal cutting.
Sawblade.com now offers the Trajan 20 heavy-duty band saw for efficient metal cutting. The semi-automatic machine features a rear roller table as well as a hydraulic saw arm lifting system plus gear drive system equipped with a variable-step pulley for making quick cuts. A buffer spring and enlarged hydraulic cylinder combine with the tungsten blade guides to promote cutting accuracy and stability. For a range of applications, the band saw provides a work capacity of 13" × 18" and a 0- to 60-degree cutting angle. A coolant system enables wet cutting.
