Bar Feeders with Synchronization
The Alpha ST 212 and ST 320 bar feeders provide reliability, stability and ease of operation, the manufacturer says. Model ST 320 feeds round barstock from 0. 12" to 0.
Moving To Magnets Doubles Productivity
