Bench-Mounted Tool Presetter Increases Productivity
Available from Koma, the Sethy tool presetter was developed as the entry-level option for Elbo Controlli’s new-generation of advanced tool presetting machines.
New Product From: 8/24/2012 Modern Machine Shop
Available from Koma, the Sethy tool presetter was developed as the entry-level option for Elbo Controlli’s new-generation of advanced tool presetting machines. Designed to be bench mounted, the Sethy features a ground granite base and column, stainless steel construction and ergonomic design controls, the company says.
The Vision System is combined with a Linux-based TFT touchscreen, which is said to provide full operator control and selection of options and functions via an intuitive menu selection. The electronics are designed to simplify operation and function.
The precision spindle system is fully interchangeable and utilizes a one-piece cartridge to eliminate the need for adaptors and errors that are commonly associated with their use, the company says.
Also included with the Sethy model is a ToolingUp software package. Working via a DNC system, ToolingUp converts measured tool data into CNC code for direct loading into the machine controller and associated tool offset pages.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Koma Precision Inc.
MMS Zones
Koma Precision Inc.
Zones
