Bi-Directional Rotation Speeds Lathe Tool Changes
The Sauter disc-type tool turret from Indexing Technologies is said to promote optimum performance on lathes, with a rigid, precise design that provides rapid indexing times.
The Sauter disc-type tool turret from Indexing Technologies is said to promote optimum performance on lathes, with a rigid, precise design that provides rapid indexing times. Turrets are available with an electro-mechanical, hydraulic, servo or synchro motor drive for precise indexing and accurate repeatability. Bi-directional rotation and ultra-high-speed drives ensure the shortest possible tool-to-tool times. The turret is compatible with VDI, BMT and most other types of toolholding and quick-change systems, the company says.
The turret comes in a range of sizes and configurations, with live tooling available on most models. High-pressure coolant, gaging, load and tool-wear monitoring, and other options are also available.
Jergens Pull Studs Enable Quick Changeovers
SP140 and K02 pull studs offer quick-change solutions for vise or gripper jaws, electronic component manufacturing, packaging machines, medical technology and automation.
How to Troubleshoot Issues With Tool Life
