Big Kaiser's HDC Jet-Through Toolholder Improves Five-Axis Surface Finish
Big Kaiser has expanded its HDC jet-through hydraulic chuck line to include the BCV interface and additional inch sizes.
Big Kaiser has expanded its HDC jet-through hydraulic chuck line to include the BCV interface and additional inch sizes. HDC toolholders are designed for high-precision five-axis machining. With maximum speeds of 35,000 rpm and clamping range of ¼" to ½", they are suitable for many applications in the automotive, aerospace, medical, and die and mold industries.
A thread feature allows for convertible coolant delivery between jet-through coolant and center-through coolant. According to the company, Jet-through hydraulic chucks are ideal toolholders for finishing applications, which benefit from improved coolant delivery. The coolant flows through the end of the toolholder and angles toward the cutting tool tip to improve surface finish and tool life.
HDC toolholders require only one hex key wrench to clamp or loosen the cutting tool, easing tool changes and eliminating any need for special equipment. The toolholder provides 0.00012" total indicator runout (TIR) at 5×D.
How to Troubleshoot Issues With Tool Life
T.J. Davies Retention Knobs Maximize Cutting Tool Life
