Blown Film Line Combines Style, Substance
WEB EXCLUSIVE: Three years in the making, unique Varex II blown-film line from W&H that debuted at K 2013 features clean, sleek look and offers upgrades in throughput and control as well.
Article From: 11/19/2013 Plastics Technology, ,
On W&H’s new Varex II blown film system, lightweight Arctis high-performance air ring offers 5-10% more output than previous versions. Its position relative to the die can be manipulated to optimize BUR. Sleek 24-in. touchscreen control interface (below) allows operators to monitor and regulate energy consumption on the line, among other functions.
In blown film extrusion, one of the highlights of K 2013 was the introduction by Windmoeller & Hoelscher (U.S. office in Lincoln, R. I.) of the Varex II line. Three years in the making, the new system was tucked into a corner of W&H’s booth and accessible by invitation only. Even then, visitors had to be escorted through a curtain and around a cordoned corridor to see the system in action.
The line featured a sleek, completely enclosed design that several onlookers thought looked more like an Apple product than typical industrial equipment. There were no cables to possibly trip over or duct work or electrical wiring in sight. The extruders and die/air-ring package were cladded—but accessible for maintenance—in what looked like fine cabinetry. A lightweight air ring made of polycarbonate was insulated to mitigate the effects of condensation.
Throughout the show, W&H made five-layer shrink collation film at 40-micron thickness. Running with a 16-in. Maxicone P die, material was processed at 2200 lb/hr, or 44 lb/hr/in. of die circumference. The trimless system ran at a layflat width of 83 in. W&H has sold seven such systems in the U.S., two of which are seven-layer.
Varex II is available with working widths up to 142 in. and can be specified for up to 11 layers. At the show, W&H ran two 60- and 70-mm (about 2.5- and 3-in.) extruders along with a 105-mm (4-in.) machine. The size range also includes 50- and 120-mm (roughly 2- and 5-in.) extruders. Die diameters range from 120 to 900 mm (5 to 35 in.)
Extruders feature what W&H calls “flow-optimized” barrier screws to provide maximum flexibility for processing a wide range of materials. A patented melt-distribution system allows for compact design of the Maxicone P die while keeping pressure losses low. The die was equipped W&H’s Optifil P auto-gauge profile control system, which enables targeted controlof the melt temperature on the bubble circumference to reduce gauge variations.
The line also featured the Arctis high-performance, dual-lip air-ring system, an upgrade of W&H’s Opticool air ring that is said to boost output by 5-10%. The air ring’s position relative to the die can be adjusted to optimize blow-up ratio. A new bubble collapsing unit in the film hauloff features automatic adjustment of the lateral guide elements, which reportedly improves film flatness while minimizing film curvature. Featuring a comprehensive range of optional specifications, the new Filmatic S II winder can be tailored to any application.
The new system also is equipped with a 24-in. touchscreen interface that includes control modules aimed at helping film processors reduce waste and improve efficiency and sustainability. These include Easy-Change, an “autopilot” for size changeovers; Easy-Wind, a winder control concept for optimum roll quality; Profile-Booster, designed to accelerate line startup; and Purge Assist, for automatic purging of the extruders and dies.
Other automation modules include Energy Monitoring, which displays the energy usage of individual system components, identifying possible energy savings in the course of production. A web-based Production Planning and Control module permits decentralized job preparation and control. Order specifications and product formulations can be transmitted directly from a plant ERP system to the extrusion line, without the operator having to enter any order data locally on the machine.
Comments are reviewed by moderators before they appear to ensure they meet Modern Machine Shop’s submission guidelines.
Learn More
