BMT Products Enable Flexibility
Heimatec will display its base mount tooling (BMT) products.
New Product From: 7/7/2014 Modern Machine Shop, ,
Heimatec will display its base mount tooling (BMT) products. In addition to standard X- and Z-axis tools, the line includes adjustable tools, speed increasers and internal coolant tools with 140 bar (2,000 psi) capabilities in a variety of tooling types, including BMT 45, 55, 65 and 75.
All tooling is supplied with the company’s U-Tec flexible machining system, which provides high-power transmission with a polygonal drive. An integrated collet nut with change-out, can convert the output to arbor (for face mills), Weldon or ER collet extensions. The system also enables closer cutting tool proximity to the bearing, resulting in higher rigidity. Cutting tools last longer and yield an improved finish as a result of this design feature, the company says.
More technology – a lot more!
IMTS 2014 will be the year’s largest showcase of new product technologies and new process innovations. If you’re looking for machining, tooling, systems, software, solutions and more, you’ll find it at IMTS 2014.
Learn More about IMTS 2014
Register Now
for IMTS 2014
Heimatec Inc.
Zones
  • Techspex
