Brazing, Soldering Machine Offers Compact Footprint
Fusion will display the Rotary Index 100, a machine for brazing and soldering, at this year’s IMTS event.
New Product From: 7/5/2014 Modern Machine Shop, ,
Fusion will display the Rotary Index 100, a machine for brazing and soldering, at this year’s IMTS event. The machine is compact, with dimensions of 48" W × 48" D. Rates are typically between 100-250 parts per hour, depending on assembly mass and configuration. Brass, copper, steel, stainless steel and aluminum can all be joined on the machine.
The production sequence begins with an operator, who loads the assembly into a stainless steel fixture. A deposit of Fusion Paste Filler Metal is applied to the joint area with an automatic dispenser. The assemblies then move through two or three flame heat stations and an air and water cooling sequence before unloading. The machine is also available with induction heat. It comes equipped with clear, acrylic guarding on three sides. Utilities required are 120 VAC, natural gas or propane and 80 psi air, water and drain.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Fusion Incorporated
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
