Breathable Drum Cover Prevents Material Contamination
Exair’s fine mesh non-woven drum cover is designed for use on 30 or 55 gallon drums and can be used with Exair’s Line Vac.
Exair’s fine-mesh, non-woven drum cover is designed for use on 30- or 55-gallon drums. The drum cover is said to prevent contamination of material and keeps material contained in the drum for a cleaner and safer work environment.
The mesh cover is said to be a simple solution when a containment vessel is needed for transferred scrap, trim waste, parts, chips or pellets. The drum cover is suitable for conveyance hoses with outside diameters ranging from a 3/4" to 3.4" (19.1 to 86.4 mm). It comes with hose clamps and a durable spring buckle strap to ease installation.
The breathable material allows the air from Exair’s Line Vac, an air operated conveyor, to circulate whether moving material in or out of a drum.
STLE Opens Registration for 2024 Annual Meeting
The Society of Tribologists and Lubrication Engineers’ 2024 STLE Annual Meeting & Exhibition will take place May 19-23 at the Minneapolis Convention Center in Minneapolis, Minnesota.
STLE To Host Metalworking Fluid Management Program
STLE’s program is a two-and-a-half-day education program offering a comprehensive overview of metalworking fluid management.
168 Manufacturing's Coolant System Automates Delivery
PMTS 2023: FullShop systems monitor and replenish all CNC machine sumps with optimized top-off ratios before the coolant runs low.
