Bridgeport V1320's Dual Y-Axis Bearings Increase Surface Quality
Hardinge has added the V1320 to Bridgeport’s V series of vertical machining centers.
Hardinge has added the V1320 to Bridgeport’s V series of vertical machining centers. The machine is designed for high capacity and performance in the aerospace, automotive and energy markets. Among the machine’s features are dual Y-axis ballscrews said to promote surface quality and roundness accuracy, acceleration, reduced vibration, and increased tool life.
With a 15" Mitsubishi M80 Color LCD touchscreen, users can pinch to zoom in and out, scroll through screens, move popup windows on the screen, or drag with a single finger. The M80 also comes with two 32-GB SD card slots for memory expansion, USB program running and high-accuracy modes.
The V1320’s oversized, 45-mm double-nut ballscrews are fixed and pre-tensioned. The large, 45-mm linear guideways are supported by six trucks on the X and Z axes.The Y axis has dual 40-mm ballscrews.
The machine has a Big Plus, 40-taper, 12,000-rpm direct-drive spindle powered by a dual-wound Mitsubishi spindle motor. A quad set of 70-mm angular contact bearings and a 60-mm rear taper roller bearing provide thermal stability, radial and axial stiffness, and high accuracy as well as 900 kg tool retention force for aggressive cutting applications.
What to Do When Five-Axis Machining Is Off the Table
For Fischer USA, 3+2 machining with a high-precision rotary table adds flexibility without the cost of a full five-axis machine.
Heavy Engineering: The Complex Logistics of Moving Large Machine Tools
One of our fascinations with large-format machine tools has little to do with their capabilities, but everything to do with the logistics involved with getting them up and running. Here’s how one of the world’s oldest builders of giant machine tools tackles the challenge.
