There are hundreds of other issues, including pallet change time and pallet repeatability.
Pallet
change time can greatly impact your “floor-to-floor” time, and the
overall part cycle time and ultimately the cost per part. Some people
measure pallet change unloaded, which can distort the actual times you
can get.
Pallet repeatability can be critical, especially
when it comes to part quality. Locating techniques, clamping, and
retaining forces must be known and measured if you really want to break
down what the cycle time can be.
Index and cycle time
characteristics can impact overall time such as tool characteristics,
like maximum size and limits. Sometimes the manufacturer will give you
a maximum length, diameter, and weight. Sometimes they’ll give you a
maximum total weight for a magazine. There are also terms such as
pockets full, adjacent pockets empty, etc. The bottom line is the
limits of the magazine.
Another aspect you don’t often see
but that can be important is maximum moment, the relationship between
the maximum size and moment, which can make the other numbers
meaningless because it can be the determining factor.
Machine
thermal control is another important aspect—temperature causes things
to grow, which will greatly affect your accuracy.
Machine control
is also important to consider, because servo and software capabilities
will affect your ability to machine effectively in both 2D and 3D.
