CAM Reduces Cycle Time From Days to Minutes
When your house is going up in flames, the last thing on your mind is whether the local hero’s firefighting equipment will do its job, and that’s exactly the way it should be.
Article From: 12/22/2010 Production Machining, Edited by: Lori Beckman,
The mini stream straightener (left) was a prototype part Task Force Tips manufactured on a multitasking machine with Esprit software. The company was able to consolidate two programs and run this parallel drive gearbox shaft (right) on a CNC lathe in one operation, with little effort, using Esprit software.
Task Force Tips CNC programmers Adam Hessling, Brandon Marcotte and Nate Price, and Production Supervisor Cory Mack (left to right)
The value of the symbiotic relationship between software and machine tool can’t be underestimated. According to the company, its biggest accomplishment regarding Esprit is using the software to fully utilize the capabilities of its machine tools.
When your house is going up in flames, the last thing on your mind is whether the local hero’s firefighting equipment will do its job, and that’s exactly the way it should be. At Task Force Tips, a manufacturer of fire-hose nozzles, the last thing on the minds of the men making its gear should be whether their CAM software will do its job.
That’s also exactly the way it should be. Task Force Tips has a total of about 180 employees in Valparaiso, Ind., where it produces firefighting equipment that controls water flow. It makes hose nozzles that automatically adjust to varying water pressure in hose lines, as well as valves and other equipment.
As a self-contained business, Task Force Tips includes an internally-fed assembly department. “We do a lot of little things on the fly, where we design it, write the program and machine it all in one day,” says Nathan Price, a CNC programmer at Task Force Tips who began his career with the company a decade ago.
The average lot size at Task Force Tips is 500, though part runs can vary in size from between 50 and 1,000 parts, says Production Supervisor Cory Mack, a 17-year company veteran.
The shop, Mr. Mack says, sees about 120 machine tool setups per week, makes about 25,000 parts per week and operates with just-in-time inventory or low inventory that is constantly turned over to keep shelving low.
When the company acquired a Mazak Integrex, a multitasking machine tool, in 2007, it chose Esprit CAM software by DP Technology to program the machine.
Like Mr. Price, Adam Hessling, a programmer in new product development who has been with Task Force Tips for 13 years, grasped the basics of Esprit fairly quickly, after about a week with the software. “I’m not always the most technically savvy person in the world, but I was able to pick it up quickly,” he says.
As it turned out, the timing could not have been better for the implementation of the software that could handle complex machining.
“When we started getting into Esprit and the Integrex, the engineers simultaneously started throwing down parts that were a lot more complicated,” Mr. Price says. In manufacturing these days, the complimentary combination of CAD software, multi-tasking machine tools and the full-spectrum CAM needed to and drive them is not unlike the age-old “chicken or the egg” argument: Which came first?
Regardless, the need for a complete solution capable of producing the increasingly complex parts demanded of manufacturers is apparent.
For CNC Programmer Brandon Marcotte, a 5-year employee at Task Force Tips, switching to Esprit has taken the guesswork out of his job. “Esprit programming is straightforward enough that it’s easy to see what changes need to be made,” Mr. Marcotte says. “It’s visual. You’re looking at solids rather than numbers, and it’s all the same no matter who’s programming it.”
Standardization and the simple assessment of necessary changes are two parts of the equation that, at its heart, is geared at generating an accurate tool path and taking the complexity out of complex machining.
“We took two steps back to take ten steps forward,” Mr. Mack says. “With Esprit, it’s a huge leap forward because the technology to produce the G code is supportive of the full capability of our machine tools.”
In the end, it’s all about saving time. For instance, in the past, to make the main body of a portable monitor (a device used when water pressure is too strong to hold a hose by hand), the part had to be loaded onto a machine tool four separate times. These operations required scheduling the workload on the floor for a month before the part went out the door, according to Mr. Price.
By implementing Esprit with the Integrex, Task Force Tips was able to cut down on machining time by streamlining processes and gained a 63-percent reduction in the time required to machine the part.
“Now we load it into a machine one time, and it’s complete,” Mr. Price says. “Before, the handling time on the part was an hour. It’s now 22 minutes. It was one of those things where you can do a couple of clicks in Esprit and have the whole thing programmed.”
The value of the symbiotic relationship between software and machine tool can’t be underestimated. “If parts had remained simple, we would have had no idea what we were missing out on,” Mr. Price says. “Our biggest accomplishment as a company regarding Esprit is that, because of the software, we can fully utilize the capabilities of our machine tools.”
Mr. Mack, echoing Mr. Price’s sentiment, adds, “What Esprit has done for us is broadened our horizons. It’s like leaving your hometown for the first time and seeing the world. This is a whole new chapter in our story. Without the software, you can have the coolest machine tool in the world, but what’s the point if you can’t make it dance?”
Accurate simulation is another new chapter in the ongoing story of Task Force Tips. Mr. Price cites a part he recently cut that, without the simulation capabilities of the CAM software, would have been headed for a collision.
This particular part was fixed to the spindle with chuck jaws, and Mr. Price would have seen, too late, that there wasn’t enough clearance on the jaws to perform the cutoff.
“We would have then had to take the time to modify the jaws,” he says. “With the software, we get to visualize everything before we even go near the machine.”
The strength of Esprit post processing was another factor in the company’s decision to implement CAM. “One barrier to switching to CAM in our shop was the post processors,” Mr. Price says. “What we post out of the software, we are able to run exactly.”
Prior to the implementation of Esprit, the staff at Task Force Tips performed manual changes, via copy and paste, and experienced several crashes as a result. Now, when an engineer makes a change, that change is saved and the production of that part is standardized. “With all of the flexibility available in the post processor, that was fairly easy to accomplish,” Mr. Price says.
“We have a strict policy against manual changes to posted code. Now I can pull up a program we last posted 2 years ago, make the necessary changes, and repost it with confidence that it will work as intended.”
That confidence has extended to automation capabilities at Task Force Tips, where Mr. Price and the rest of the team have made plenty of headway and are continuing to explore the possibilities inherent to this arena.
Thus far, Mr. Price says, they’ve worked with the included Visual Basic macro language to establish automation activities within Esprit.
“We’ve automated WPC creation so we can begin programming a 24-station fixture in just a couple of minutes—a task that used to be anywhere from 15 to 30 minutes,” Mr. Price says. “We’ve automated loading and positioning toolholders on a turret lathe simulation, so we can have all tools in place and ready for simulation in less than 5 minutes. This would have taken a very long time, but we never tried it the manual way.”
They’ve also created macros to generate custom helical tool paths to use lathes with milling capacity to mill the sharp edges off of threads. “We’ve also been able to fully incorporate ‘thrillers’ (a tool by Emuge that will do spot drilling, drilling and threading as a single tool) in our programs via a macro that generates the correct tool path for accurate simulation and cutting,” Mr. Price says.
For Mr. Hessling, the establishment of Esprit on the shop floor has led to innovative design. He machines new castings, designs fixturing and performs production programming. “The difference now is that there are just so many more possibilities for the engineers,” he says.
The company also reduced on-site injuries by decreasing the need for deburring by hand. The majority of deburring can now be completed on the machine tool.
“We’ve been able to do certain things with tool path that have reduced the workload for our secondary operations department,” Mr. Price explains. “It used to take two people 8 hours a day, 5 days a week, to debur by hand. Now it takes one person a half a day, 5 days a week.”
Overall, Mr. Mack says, the operations department is doing 50 percent less work because of the deburring and chamfer capabilities in the software. As the company has been able to reduce the cost of parts, it has become more competitive in the marketplace.
There’s no doubt that the pioneering spirit of the team at Task Force Tips has played a large part in its success, though Mr. Mack credits its software with the ability to take them where they want to go.
“With Esprit, you are carrying the sword that can slay any dragon you want,” Mr. Mack says. “We went to a high level in a short period of time. It’s so much more powerful than anything else. It’s a huge stride in a new direction that is going to make us more profitable.” For more information from DP Technology, call 800-627-8479 or visit productionmachining.com/suppliers.
Editor's Picks
CAM For Multitasking Operations
While still running a few different CAM systems in the shop, this manufacturer of aerospace and oil and gas industry components has implemented wha...
ESPRIT by DP Technology Corp.
MMS Zones
Editor's Picks
Zones
Supplier Categories
