CAM Software Version Emphasizes Automation Capabilities
The hyperMILL 2010.1 CAM software edition is the company’s first package designed with 64-bit computing in mind. This version also includes continued emphasis on providing automation capabilities allowing the ability to store proven machining procedures, reuse corporate knowledge, add logic, make powerful programming macros and even drive hyperMILL from external applications using an API interface, the company says.
New Product From: 6/23/2010 Modern Machine Shop
The hyperMILL 2010.1 CAM software edition is the company’s first package designed with 64-bit computing in mind. This version also includes continued emphasis on providing automation capabilities allowing the ability to store proven machining procedures, reuse corporate knowledge, add logic, make powerful programming macros and even drive hyperMILL from external applications using an API interface, the company says. This software version can be used for 2.5- through 5-axis milling and turning, and is supported by company-developed postprocessors.
• 2-5 Axis Milling
Get the Edge with iMachining - the revolution in CNC Machining. Time savings up to 70%!
Increase your productivity and bottom line with SURFCAM!
www.surfcam.com
HSMXpress is full
featured 2 1/2-axis
CAM for SolidWorks.
Best of all, HSMXpress
is absolutely FREE!
SmartCAM V18.5 features New Mill/Turn Sub-Spindle and B-axis Support, Morph Pattern Roughing.
Simulate, verify, & optimize CNC machines with VERICUT
