Centerless Grinder Resists Deflection
Royal Master Grinders offers its TG-12x8 centerless grinder, which features wide wheels and a compact design, in through-feed, in-feed, high-accuracy and CNC versions.
New Product From: 8/29/2014 Modern Machine Shop, ,
Royal Master Grinders offers its TG-12x8 centerless grinder, which features wide wheels and a compact design, in through-feed, in-feed, high-accuracy and CNC versions. The centerless grinder offers a diameter capacity of 3" (75 mm), a grinding wheel diameter of 12" (300 mm) and a regulating wheel diameter of 8" (203 mm). Both the grinding and regulating wheels are 8" (203 mm) wide.  The grinding wheel spindle has 4"-diameter (100-mm-diameter) bearings with three sets of class 7 ABEC angular contact Timken bearings, and is housed inside a larger headstock with an outboard bearing for a twin-grip design that is said to improe grinding wheel accuracy. The regulating wheel’s 2.25" (57-mm) spindle and Timken support bearings enable grinding demanding applications with zero deflection, the company says.
The grinding machine is constructed on the company’s 8"-thick (203-mm-thick) Starrett surface-plate-quality granite with a 0.002" (5-micron) flatness specification for improved rigidity and thermal properties. Regulating wheel spindles are servo-driven, while dressers feature hydraulics. The regulating wheel servo-drive provides 170 foot-pounds of continuous torque with a 10:1 gearbox. Dressers are offered as air-sensing, automatic-dressing, over-the-wheel CNC and rotary diamond disc CNC platforms. A longer, wider ram bed offers improved positioning and is virtually friction-free. The entire ram bed swivels with the work rest holder, making it easier to advance the unit after dressing, reducing setup time.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Royal Master Grinders, Inc.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
