Chuck Jaws Grip Thin-Walled Parts
U S Shop Tools has expanded its line of Round Jaws for manual and CNC lathe chucks with sizes now ranging from 6" to as large as 28" in diameter.
U S Shop Tools has expanded its line of Round Jaws for manual and CNC lathe chucks with sizes now ranging from 6" to as large as 28" in diameter. Available in a variety of heights, the jaws are manufactured from 1018 or 1050 steel and 6061-T6 or A319 extruded aluminum. Suitable for thin-walled or irregular shaped parts, the jaws enable complete gripping while distributing pressure evenly throughout the workpiece. The jaws are also said to help maintain concentricity and hold close tolerances.
Simple Workholding for Robotic Automation
When To Use A Collet Chuck
