Chucks Prevent Tool Pullout
Iscar’s Hydro-Sure adapter chucks for standard Weldon shank tools combine hydraulic and side-screw clamping to prevent tool pullout.
Iscar’s Hydro-Sure adapter chucks for standard Weldon shank tools combine hydraulic and side-screw clamping to prevent tool pullout. The adapters provide high-torque transmission on Weldon-type tools with an accurate concentricity of 0.003 mm. The chucks are said to prevent axial and radial movement of the cutter, and the rigid peripheral hydraulic clamping provides vibration damping. The chucks are well-suited for both heavy-duty and finishing applications, and provide quality surface finish and extended tool life in high-performance cutting operations. A variety of sizes are available for tool diameters ranging from 16 to 32 mm.
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
