Automatic Lathe Promotes Faster Cycle Times, Ease of Use
Marubeni Citizen-Cincom presents six Miyano machines including the Miyano BNE-51MSY fixed-headstock type CNC automatic lathe.
Marubeni Citizen-Cincom presents six Miyano machines including the Miyano BNE-51MSY fixed-headstock type CNC automatic lathe. The BNE series is designed for high rigidity, heavy cutting capability and precision. The MSY model includes an X3 axis on the back spindle and synchronized, superimposed control for three-tool simultaneous machining, providing faster cycle times, ease of use and the ability to machine complex workpieces, the company says. Features include a high-rigidity spindle, hand-scraped box slideways on all axes, a durable bed and high-accuracy turrets with two 12-station turrets.
Additional Miyano machines s presented include the BNA-42S2 turning center with a FANUC robot system, BNA-42GTY with the MCC L2000 Laser System, BNJ-51SY6, GN3200 and MC20.
  • 10 Things to Know About Creep-Feed Grinding
  • Inside an Amish-Owned Family Machine Shop
    Modern Machine Shop took an exclusive behind-the-scenes tour of an Amish-owned machine shop, where advanced machining technologies work alongside old-world traditions.
