CNC Bar Pullers For Low-Cost Automation
Royal Products says its range of CNC bar pullers can automate virtually any CNC lathe or turning center freeing operators to handle other tasks.
Royal Products says its range of CNC bar pullers can automate virtually any CNC lathe or turning center freeing operators to handle other tasks. The bar pullers are said to be easy to set up and use, requiring no electrical interface with the machine tool control. According to the company, they don’t waste floor space and can be moved from machine to machine as jobs require.
Moving To Magnets Doubles Productivity
Simple Workholding for Robotic Automation
