CNC Drill Bit Sharpener
Darex will be exhibiting the XPS-16 automatic CNC drill bit sharpener at IMTS 2012.
New Product From: 7/4/2012 Modern Machine Shop
Darex will be exhibiting the XPS-16 automatic CNC drill bit sharpener. According to the company, this is an extremely accurate and versatile sharpener for high-tech applications. It can sharpen two-fluted HSS, cobalt, carbide and coated bits. It can sharpen to any angle from 118 to 150 degrees, and any bit between 3 and 16 mm in diameter. The sharpener’s CNC control allows the user to customize point styles for their needs and save them for future use.
This model features a number of updates, including doubling the number of stored drill files. The upgraded model also allows for split only operations, letting the user choose between no-split, X-split, R-split and split-only options. According to the company, the new sharpener is 20 percent faster. The start of the grind position has been incremented for a more efficient use of the abrasive for longer wheel life. In addition, greater resolution has been added to the motors for improved surface finish.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Darex
MMS Zones
Darex
Zones
