CNC Interface Facilitates Manufacture of Complex Workpieces
Siemens Industry’s Sinumerik Operate integrates HMI-Advanced, ShopMill and ShopTurn into a single machine tool user interface.
Siemens Industry’s Sinumerik Operate integrates HMI-Advanced, ShopMill and ShopTurn into a single machine tool user interface. It contains new functions that facilitate the setup and manufacture of complex workpieces.
Used for the company’s 828D and 840D sl CNCs, the single interface is said to enable fast sequence as well as high-level language programming and work preparation. The layout, with context-based functions and icons, facilitates handling for machine operators. Various kinematics are easy setup, while integrated simulations and different workplace views enable users to quickly check the programming. Users can also zoom into angled levels individually while a simulation is running.
The interface shows animated measurements for both switched and manual tool measurement features, and the Cycle 800 swivel cycle is designed to enable the manufacture of complex workpieces with simple and fast handling. Its tool and program management system features a configurable, structured tool list that displays relevant data.
ShopMill and ShopTurn sequence programming can be used to create custom programming solutions for the manufacture of individual parts and small batch sizes. The company’s programGuide combines G-code programming with cycle support for flexibility and short machining times.
  • From Tradition to Transformation: Century-Old Manual Machine Shop Adds CNCs
    After 122 years of working with manual mills and lathes, this fifth-generation shop acquired assets of a local CNC machining business and hired the owner. Here’s how it’s going a year later.
  • 7 CNC Parameters You Should Know
  • Generating a Digital Twin in the CNC
Gardner Business Intelligence
Gravotech
High Accuracy Linear Encoders
