CNC Lathe Provides High Axial And Radial Load Capacities
Jarng Yeong’s HCP/HC series CNC lathe is built with a stable body structure, one cast molding and a tempering treatment intended to ensure the life of the lathe’s mechanical accuracy. The lathe’s X and Z axes are available for slide guideways or linear guideways. The spindle is made from high-alloy steel and is har
New Product From: 8/6/2008 Modern Machine Shop
Jarng Yeong’s HCP/HC series CNC lathe is built with a stable body structure, one cast molding and a tempering treatment intended to ensure the life of the lathe’s mechanical accuracy. The lathe’s X and Z axes are available for slide guideways or linear guideways. The spindle is made from high-alloy steel and is hardened by precision grinding with precision P4-class ball bearings. According to the company, the spindle provides high axial and radial load capacities and quality cutting performance. A self-luminous control panel, 10.4 TFT LCD screen, path simulation and handwheel simulation come standard. The spindle can accommodate a three-jaw chuck or a collet chuck for practicability in turning a single workpiece or bar. A variety of optional accessories are also available to achieve complete processing of complex functions.
Jarng Yeong Enterprise Co. Ltd
MMS Zones
FUJI machines are built for automation from the ground up.
