CNC Machine Fire Suppression System
The company’s automatic fire suppression systems are suited for CNC machines that use oil-based lubricants, which can overheat, ignite and cause a flash fire. Featuring a flexible polymer tubing that ruptures when exposed to a flame, these automatic systems detect and suppress a fire by flooding the machining area with a suppression agent and turning the power off. The machine can be returned to service within an hour.
3+3 Air Chuck Features Extended Stroke and Self-Centering
To keep up with the demands of the oil and gas industry, SMW Autoblok introduces BBFZA2G Air Chuck, featuring an extended stroke clamping range and three self-centering jaws.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
Dielectric Oil Dramatically Reduces EDM Maintenance
Plagued by repeated small fires that interrupted its wire EDM throughput, this cutting tool manufacturer changed its dielectric oil and both eliminated fires and reduced its oil consumption.
