CNC Tool and Cutter Grinder
The small-footprint FastGrind CNC tool and cutter grinder is designed for high-speed resharpening of tools ranging to 9.4" in diameter using custom iGrind software.
New Product From: 4/12/2010 Modern Machine Shop
The small-footprint FastGrind CNC tool and cutter grinder is designed for high-speed resharpening of tools ranging to 9.4" in diameter using custom iGrind software. The machine is said to offer high positioning accuracies in all five mechanical axes, plus an additional four software axes. Linear axes are ballscrew-driven and the two rotary axes are direct-driven.
The machine sharpens drills, step drills, end mills, burrs, profile tools, routers and special tools using a double-ended HSK40 wheel spindle to increase flexibility and reduce setup time. It features a maximum 8" wheel diameter as well as a standard part-probing system and optional tool inspection software package.
ANCA, Inc.
MMS Zones
ANCA, Inc.
Zones
Supplier Categories
LANDIS ECOFLEX Grinder - flexibility to reduce your carbon footprint without sacrificing quality or productivity
