Cold Cut Saw Enables Low-rpm Cutting
Grizzly’s Model G0783 cold cut saw features a two-speed, 2.7/1.9-hp, 220-V three-phase motor.
Grizzly’s Model G0783 cold cut saw features a two-speed, 2.7/1.9-hp, 220-V three-phase motor. Its gear-driven blades cut at either 114 or 57 rpm and are kept cool by the built-in blade coolant system with single-phase coolant pump. The saw accepts a 275-mm (11") blade on a 32-mm (1.26") arbor. It is capable of cutting angles ranging from 45 to 90 degrees with a vise jaw maximum depth of 4.5" and height of 2". The saw is mounted on a solid cast iron table and cabinet for storage.
