Collet Chuck-Style Broach Toolholders
The new collet chuck-style broach toolholders are said to be versatile because they use ER-style collets, which are designed to reduce the three-screw method of centering the HSS broach in the broach toolholder. The ER-style collet will hold virtually any diameter shank broach tool in the holder within the range of the collet. A built-in stop screw allows the operator to adjust for different length broaches and to compensate for different lengths on re-sharpened broaches.
A built-in stop screw allows the operator to adjust for different length broaches and to compensate for different lengths on re-sharpened broaches. The collet chuck-style broach holder also eliminates the need for centering the cutting tool to “spindle” of the broaching holder, and there are no screws to knock the cutting tool off center.
Successful applications include the producing of various internal-shaped forms such as hex, square, double hex, straight spline, involute spline, multi keyway, knurl and socket heads.
GenSwiss Releases Redesigned Toolholding System
Its GenQuick quickchange ER system for Swiss-type CNC machines and precision machining equipment has been updated.
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
