Combination Sump Cleaner and Dispenser
Cecor’s CE-30 Extra-Power twin-tank sump cleaner and dispenser features two 60-gallon tanks on a single chassis, one for cleaning and one for dispensing.
Cecor’s CE-30 Extra-Power twin-tank sump cleaner and dispenser features two 60-gallon tanks on a single chassis, one for cleaning and one for dispensing. The sump cleaner tank sucks out the contents of a machine tool sump via the 3-hp electric motor that generates suction ranging to 13" Hg (177" water). A 2.3-ft.3 filter capable of holding as much as 350 lbs catches chips and swarf while the filtered coolant enters the tank. The coolant can then be pumped back into the sump for additional use or transported for batch recycling. Users can quickly top off the coolant sump with fresh coolant from the dispenser tank. Both tanks offer pump-in and pump-out capabilities, with pumping rate ranging to 60 gpm and pressure discharge of 6 psi. The system features automatic overfill protection, and all discharge ports are valved. According to the company, the unit is compact enough to move easily down aisles and through small spaces.
Managing Coolant with Skimmers, Refractometers and More
Bacteria-infected coolant harms machines and sickens machinists. Coolant management technologies like skimmers and automated systems counter this tendency.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
168 Manufacturing's Coolant System Automates Delivery
PMTS 2023: FullShop systems monitor and replenish all CNC machine sumps with optimized top-off ratios before the coolant runs low.
