Compact, High-Speed Spindles Enable Ultra-Small Drilling
IBAG North America offers its Micro Line compact, high-speed spindles for Swiss-type turning machines.
IBAG North America offers its Micro Line compact, high-speed spindles for Swiss-type turning machines. Spindle sizes range from 16 to 33 mm in diameter with speeds ranging to 120,000 rpm and power to 390 W. Suitable for use with the Micro Line’s 22-, 25- and 33-mm standard, back-working and right-angle spindles, the company’s micro collet system delivers accuracies of 1 micron TIR at the collet nose and handles tool diameters ranging to 1/8". The collets enable higher accuracies for precision milling and small drilling applications, the company says.
How Lowering Torque Improves Tapping Tool Life
Escaping the tap breakage trap requires a long look at torque and the many factors that influence it.
Walter Launches New Solid Carbide Drill
The DC118 Supreme solid carbide drill provides high rigidity against deflection, superior centering accuracy and four margins with corner chamfers.
